On the regularization of Sliced Inverse Regression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sliced Inverse Regression (SIR) is an effective method for dimension reduction in high dimensional regression problems. The original method, however, requires the inversion of the predictors covariance matrix. In case of collinearity between these predictors or small sample sizes compared to the dimension, the inversion is not possible and a regularization technique has to be used. Our approach is based on an interpretation of SIR axes as solutions of an inverse regression problem. A prior distribution is then introduced on the unknown parameters of the inverse regression problem in order to regularize their estimation [3]. We show that some existing SIR regularizations can enter our framework, which permits a global understanding of these methods [2]. Three new priors are proposed, leading to new regularizations of the SIR method, and compared on simulated data. An application to the estimation of Mars surface physical properties from hyperspectral images [1] is provided. -- References : [1] C. Bernard-Michel, S. Douté, M. Fauvel, L. Gardes & S. Girard. "Retrieval of Mars surface physical properties from OMEGA hyperspectral images using Regularized Sliced Inverse Regression", Journal of Geophysical Research - Planets, 114, E06005, 2009. [2] C. Bernard-Michel, L. Gardes & S. Girard. "A Note on Sliced Inverse Regression with Regularizations", Biometrics, 64, 982--986, 2008. [3] C. Bernard-Michel, L. Gardes & S. Girard. "Gaussian Regularized Sliced Inverse Regression", Statistics and Computing, 19, 85--98, 2009.
Fichier non déposé
hal-00762725 , version 1 (07-12-2012)
  • HAL Id : hal-00762725 , version 1
Stéphane Girard. On the regularization of Sliced Inverse Regression. Statlearn'10 - Workshop on Challenging problems in Statistical Learning, Jan 2010, Paris, France. pp.CDROM. ⟨hal-00762725⟩
90 Consultations
0 Téléchargements
