Greenland Ice Sheet contribution to sea-level rise from a new-generation ice-sheet model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Cryosphere Année : 2012
Over the last two decades, the Greenland Ice Sheet (GrIS) has been losing mass at an increasing rate, enhancing its contribution to sea-level rise. The recent increases in ice loss appear to be due to changes in both the surface mass balance of the ice sheet and 5 ice discharge (ice flux to the ocean). Rapid ice flow directly affects the discharge, but also alters ice-sheet geometry and so affects climate and surface mass balance. The most usual ice-sheet models only represent rapid ice flow in an approximate fashion and, as a consequence, have never explicitly addressed the role of ice discharge on the total GrIS mass balance, especially at the scale of individual outlet glaciers. Here, 10 we present a new-generation prognostic ice-sheet model which reproduces the current patterns of rapid ice flow. This requires three essential developments: the complete solution of the full system of equations governing ice deformation; an unstructured mesh to usefully resolve outlet glaciers and the use of inverse methods to better constrain poorly known parameters using observations. The modelled ice discharge is in good 15 agreement with observations on the continental scale and for individual outlets. By conducting perturbation experiments, we investigate how current ice loss will endure over the next century. Although we find that increasing ablation tends to reduce outflow and on its own has a stabilising effect, if destabilisation processes maintain themselves over time, current increases in the rate of ice loss are likely to continue.
tcd-6-2789-2012.pdf (2.04 Mo) Télécharger le fichier
hal-00762945 , version 1 (09-12-2012)
Fabien Gillet-Chaulet, Olivier Gagliardini, Hakime Seddik, Maëlle Nodet, Gaël Durand, et al.. Greenland Ice Sheet contribution to sea-level rise from a new-generation ice-sheet model. The Cryosphere, 2012, 6 (6), pp.1561-1576. ⟨10.5194/tcd-6-2789-2012⟩. ⟨hal-00762945⟩
820 Consultations
398 Téléchargements
