Nomographic Gossiping for f-Consensus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a novel class of iterative gossip algorithms called nomographic gossiping that partly allow to efficiently achieve a rapid global consensus among nodes/agents in a clustered wireless network with respect to an arbitrary function of the initial states. The algorithms are based on the surprising fact that every real-valued multivariate function has a nomographic representation, which is simply a function of a superposition of a finite number of univariate functions. Since superpositions can be effectively generated via the wireless channel by letting nodes in a cluster transmit simultaneously their pre-processed states to a cluster head, the convergence speed can be significantly increased provided that some connectivity condition between clusters is fulfilled.
p130-goldenbaum.pdf (582.09 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00763402 , version 1 (10-12-2012)
  • HAL Id : hal-00763402 , version 1
Mario Goldenbaum, Holger Boche, Sławomir Stanczak. Nomographic Gossiping for f-Consensus. WiOpt'12: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2012, Paderborn, Germany. pp.130-137. ⟨hal-00763402⟩
Collections
WIOPT2012
70 Consultations
216 Téléchargements
