Numerical simulation of diffusion MRI signals using an adaptive time-stepping method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physics in Medicine and Biology Année : 2013
The effect on the MRI signal of water diffusion in biological tissues in the presence of applied magnetic field gradient pulses can be modelled by a multiple compartment Bloch-Torrey partial differential equation. We present a method for the numerical solution of this equation by coupling a standard Cartesian spatial discretization with an adaptive time discretization. The time discretization is done using the explicit Runge-Kutta-Chebyshev method, which is more efficient than the forward Euler time discretization for diffusive-type problems. We use this approach to simulate the diffusion MRI signal from the extra-cylindrical compartment in a tissue model of the brain gray matter consisting of cylindrical and spherical cells and illustrate the effect of cell membrane permeability.
main.pdf (1.89 Mo) Télécharger le fichier
hal-00763888 , version 1 (13-12-2012)
hal-00763888 , version 2 (07-01-2014)
Jing-Rebecca Li, Donna Calhoun, Cyril Poupon, Denis Le Bihan. Numerical simulation of diffusion MRI signals using an adaptive time-stepping method. Physics in Medicine and Biology, 2013, ⟨10.1088/0031-9155/59/2/441⟩. ⟨hal-00763888v1⟩
325 Consultations
561 Téléchargements
