Assessing the reconstruction of macromolecular assemblies with toleranced models. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proteins - Structure, Function and Bioinformatics Année : 2012
Valérie Doye
Frédéric Cazals
We introduce toleranced models (TOMs), a generic and versatile framework meant to handle models of macromolecular assemblies featuring uncertainties on the shapes and the positions of proteins. A TOM being a continuum of nested shapes, the inner (resp. outer) ones representing high (low) confidence regions, we present topological and geometric statistics assessing features of this continuum at multiple scales. While the topological statistics qualify contacts between instances of protein types and complexes involving prescribed protein types, the geometric statistics scale the geometric accuracy of these complexes. We validate the TOM framework on recent average models of the entire nuclear pore complex (NPC) obtained from reconstruction by data integration, and confront our quantitative analysis against experimental findings related to complexes of the NPC, namely the Y-complex, the T-complex, and the Nsp1-Nup82-Nup159 complex. In the three cases, our analysis bridges the gap between global qualitative models of the entire NPC, and atomic resolution models or putative models of the aforementioned complexes. In a broader perspective, the quantitative assessments provided by the TOM framework should prove instrumental to implement a virtuous loop "model reconstruction-model selection", in the context of reconstruction by data integration.
hal-00764009 , version 1 (12-12-2012)
Tom Dreyfus, Valérie Doye, Frédéric Cazals. Assessing the reconstruction of macromolecular assemblies with toleranced models.. Proteins - Structure, Function and Bioinformatics, 2012, 80 (9), pp.2125-36. ⟨10.1002/prot.24092⟩. ⟨hal-00764009⟩
231 Consultations
0 Téléchargements
