A Skeleton Based Descriptor for Detecting Text in Real Scene Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a new method for text extraction in real scene images. We propose first a skeleton based descriptor to describe the strokes of the text candidates that compose a spatial relation graph. We then apply the graph cuts algorithm to label the nodes of the graph as text or non-text. We finally refine the resulted text lines candidates by classifying them using a kernel SVM. To validate this approach we perform a set of tests on the public datasets ICDAR 2003 and 2011.
ICPR_2012_camera_ready.pdf (839.62 Ko) Télécharger le fichier
hal-00764633 , version 1 (13-12-2012)
  • HAL Id : hal-00764633 , version 1
Mehdi Felhi, Nicolas Bonnier, Salvatore Tabbone. A Skeleton Based Descriptor for Detecting Text in Real Scene Images. 21st International Conference on Pattern Recognition - ICPR 2012, Nov 2012, Tsukuba, Japan. pp.282-285. ⟨hal-00764633⟩
134 Consultations
322 Téléchargements
