Building a global time on parallel machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1989
This paper presents a pragmatic algorithm to build a global time on any distributed system, which is optimal for homogeneous parallel machines. After some discution on time, clocks and distributed systems, we survey and criticize the classical approaches based on clock synchronisation techniques. Satisfying better our purposes, a statistical method is chosen as a building block to derive an original algorithm valid for any topology. This algorithm is particularly well suited for distributed algorithm experimentation purposes because, after an acquisition phasis, it induces neither CPU nor message overhead. We provide in the conclusion some data about its behavior and performances on some parallel machines.
nice89.pdf (193.29 Ko) Télécharger le fichier
hal-00765061 , version 1 (12-03-2019)
  • HAL Id : hal-00765061 , version 1
Jean-Marc Jézéquel. Building a global time on parallel machines. Proc. of the 3rd International Workshop on Distributed Algorithms, Sep 1989, Nice, France. ⟨hal-00765061⟩
100 Consultations
166 Téléchargements
