Computer-Aided Cryptographic Proofs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Provable security [6] is at the heart of modern cryptography. It advocates a mathematical approach in which the security of new cryptographic constructions is defined rigorously, and provably reduced to one or several assumptions, such as the hardness of a computational problem, or the existence of an ideal functionality. A typical provable security statement is of the form: for all adversary against the cryptographic construction TeX , there exists an adversary TeX against a security assumption TeX , such that if TeX has a high probability of breaking the scheme TeX in time t, then TeX has a high probability of breaking the assumption TeX in time t′ (defined as a function of t).
main.pdf (53.36 Ko) Télécharger le fichier
hal-00765869 , version 1 (17-12-2012)
Gilles Barthe, Benjamin Grégoire, Santiago Zanella-Béguelin. Computer-Aided Cryptographic Proofs. Static Analysis - 19th International Symposium, SAS 2012, Sep 2012, Deauville, France. ⟨10.1007/978-3-642-33125-1_1⟩. ⟨hal-00765869⟩
Collections
INRIA INRIA2
218 Consultations
270 Téléchargements
