Low Speed Automation, a French Initiative - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nowadays, vehicle safety is constantly increasing thanks to the improvement of vehicle passive and active safety. However, on a daily usage of the car, traffic jams remains a problem. With limited space for road infrastructure, automation of the driving task on specific situation seems to be a possible solution. The French project ABV, which stands for low speed automation, tries to demonstrate the feasibility of the concept and to prove the benefits. In this article, we describe the scientific background of the project and expected outputs.
ArticleFawzi_TRA2012_paper_final_366_Word.pdf (456.19 Ko) Télécharger le fichier
hal-00767429 , version 1 (19-12-2012)
Sébastien Glaser, Maurice Cour, Lydie Nouveliere, Alain Lambert, Fawzi Nashashibi, et al.. Low Speed Automation, a French Initiative. TRA 2012 - Transport Research Arena Conference, Apr 2012, Athènes, Greece. ⟨hal-00767429⟩
275 Consultations
234 Téléchargements
