RIOT: One OS to Rule Them All in the IoT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
The Internet of Things (IoT) embodies a wide spectrum of machines ranging from sensors powered by 8-bits microcontrollers, to devices powered by processors roughly equivalent to those found in entry-level smartphones. Neither traditional operating systems (OS) currently running on internet hosts, nor typical OS for sensor networks are capable to fulfill all at once the diverse requirements of such a wide range of devices. Hence, in order to avoid redundant developments and maintenance costs of IoT products, a novel, unifying type of OS is needed. The following analyzes requirements such an OS should fulfill, and introduces RIOT, a new OS satisfying these demands.
RR-8176.pdf (623 Ko) Télécharger le fichier
hal-00768685 , version 1 (03-01-2013)
hal-00768685 , version 2 (07-01-2013)
hal-00768685 , version 3 (16-01-2013)
  • HAL Id : hal-00768685 , version 1
Emmanuel Baccelli, Oliver Hahm. RIOT: One OS to Rule Them All in the IoT. [Research Report] RR-8176, 2012. ⟨hal-00768685v1⟩
Collections
INRIA-RRRT
4654 Consultations
7365 Téléchargements
