Brief Announcement: Semantics of Eventually Consistent Replicated Sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper studies the semantics of sets under eventual consistency. Eventual consistency of replicated data supports concurrent updates, reduces latency and improves fault tolerance, but forgoes strong consistency (e.g., linearisability). The sequential semantics of a set are well known, and are defined by in- dividual updates, e.g., {true}add(e){e ∈ S} (in "{pre-condition} computation {post-condition}" notation), where S denotes its abstract state. However, the semantics of concurrent modifications is left underspecified or implementation- driven.
Autre [cs.OH]
semantics-sets-BA-DISC-2012.pdf (146.11 Ko) Télécharger le fichier
hal-00769554 , version 1 (02-01-2013)
Annette Bieniusa, Marek Zawirski, Nuno Preguiça, Marc Shapiro, Carlos Baquero, et al.. Brief Announcement: Semantics of Eventually Consistent Replicated Sets. DISC 2012 - 26th International Symposium on Distributed Computing, Oct 2012, Salvador, Bahia, Brazil. pp.441--442, ⟨10.1007/978-3-642-33651-5_48⟩. ⟨hal-00769554⟩
555 Consultations
209 Téléchargements
