Extension of the chemostat model with flocculation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Analysis and Applications Année : 2013
In this work, we study a model of the chemostat where the species are present in two forms, isolated and aggregated individuals, such as attached bacteria or bacteria in flocks. We show that our general model contains a lot of models that were previously considered in the literature. Assuming that flocculation and deflocculation dynamics is fast compared to the growth of the species, we construct a reduced chemostat-like model in which both the growth functions and the apparent dilution rate depend on the density of the species. We also show that such a model involving monotonic growth rates may exhibit bi-stability, while it may occur in the classical chemostat model, but when the growth rate is non-monotonic.
mo2013-pub00036453.pdf (381.11 Ko) Télécharger le fichier
hal-00777539 , version 1 (17-01-2013)
Radhouane Fekih-Salem, Jérôme Harmand, Claude Lobry, Alain Rapaport, Tewfik Sari. Extension of the chemostat model with flocculation. Journal of Mathematical Analysis and Applications, 2013, 397 (1), pp.292-306. ⟨10.1016/j.jmaa.2012.07.055⟩. ⟨hal-00777539⟩
256 Consultations
159 Téléchargements
