Reconciling faceted search and query languages for the Semantic Web - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Int. J. Metadata, Semantics and Ontologies Année : 2012
Faceted search and querying are two well-known paradigms to search the Semantic Web. Querying languages, such as SPARQL, offer expressive means for searching RDF datasets, but they are difficult to use. Query assistants help users to write well-formed queries, but they do not prevent empty results. Faceted search supports exploratory search, i.e., guided navigation that returns rich feedbacks to users, and prevents them to fall in dead-ends (empty results). However, faceted search systems do not offer the same expressiveness as query languages. We introduce Query-based Faceted Search (QFS), the combination of an expressive query language and faceted search, to reconcile the two paradigms. We formalize the navigation of faceted search as a navigation graph, where navigation places are queries, and navigation links are query transformations. We prove that this navigation graph is \em safe (no dead-end), and \em complete (every query that is not a dead-end can be reached by navigation). In this paper, the LISQL query language generalizes existing semantic faceted search systems, and covers most features of SPARQL. A prototype, Sewelis, has been implemented, and a usability evaluation demonstrated that QFS retains the ease-of-use of faceted search, and enables users to build complex queries with little training.
main.pdf (458.06 Ko) Télécharger le fichier
hal-00779925 , version 1 (22-01-2013)
  • HAL Id : hal-00779925 , version 1
Sébastien Ferré, Alice Hermann. Reconciling faceted search and query languages for the Semantic Web. Int. J. Metadata, Semantics and Ontologies, 2012, 7 (1), pp.37-54. ⟨hal-00779925⟩
306 Consultations
519 Téléchargements
