Call-by-Value solvability, revisited
In the call-by-value lambda-calculus solvable terms have been characterised by means of call-by-name reductions, which is disappointing and requires complex reasonings. We introduce the value substitution lambda-calculus, a simple calculus borrowing ideas from Herbelin and Zimmerman's call-by-value lambda-CBV calculus and from Accattoli and Kesner's substitution calculus lambda-sub. In this new setting, we characterise solvable terms as those terms having normal form with respect to a suitable restriction of the rewriting relation.
Logique en informatique [cs.LO]Origine | Fichiers produits par l'(les) auteur(s) |
