Data Gathering and Personalized Broadcasting in Radio Grids with Interferences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
In the gathering problem, a particular node in a graph, the base station, aims at receiving messages from some nodes in the graph. At each step, a node can send one message to one of its neighbor (such an action is called a call). However, a node cannot send and receive a message during the same step. Moreover, the communication is subjet to interference constraints, more precisely, two calls interfere in a step, if one sender is at distance at most dI from the other caller. Given a graph with a base station and a set of nodes having some messages, the goal of the gathering problem is to compute a schedule of calls for the base station to receive all messages as fast as possible, i.e., minimizing the number of steps (called makespan). The gathering problem is equivalent to the personalized broadcasting problem where the base station has to send messages to some nodes in the graph, with same transmission constraints. In this paper, we focus on the gathering and personalized broadcasting problem in grids. Moreover, we consider the non-buffering model: when a node receives a message at some step, it must transmit it during the next step. In this setting, though the problem of determining the complexity of computing the optimal makespan in a grid is still open, we present linear (in the number of messages) algorithms that compute schedulesforgatheringwithdI ∈{0,1,2}.Inparticular,wepresentanalgorithmthatachievestheoptimal makespanuptoanadditiveconstant2whendI =0.Ifnomessagesare"close"totheaxes(thebasestation being the origin), our algorithms achieve the optimal makespan up to an additive constant 1 when dI = 0, 4 when dI = 2, and 3 when both dI = 1 and the base station is in a corner. Note that, the approximation algorithms that we present also provide approximation up to a ratio 2 for the gathering with buffering. All our results are proved in terms of personalized broadcasting.
RR-8218.pdf (885.59 Ko) Télécharger le fichier
hal-00783198 , version 1 (31-01-2013)
hal-00783198 , version 2 (05-02-2013)
  • HAL Id : hal-00783198 , version 1
Jean-Claude Bermond, Bi Li, Nicolas Nisse, Hervé Rivano, Min-Li Yu. Data Gathering and Personalized Broadcasting in Radio Grids with Interferences. [Research Report] RR-8218, 2013. ⟨hal-00783198v1⟩
Collections
INRIA-RRRT
280 Consultations
238 Téléchargements
