Efficient Distributed Monitoring with Active Collaborative Prediction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Future Generation Computer Systems Année : 2013
Isolating users from the inevitable faults in large distributed systems is critical to Quality of Experience. We formulate the problem of probe selection for fault prediction based on end-to-end probing as a Collaborative Prediction (CP) problem. On an extensive experimental dataset from the EGI grid, the combination of the Maximum Margin Matrix Factorization approach to CP and Active Learning shows excellent performance, reducing the number of probes typically by 80% to 90%. Comparison with other Collaborative Prediction strategies show that Active Probing is most efficient at dealing with the various sources of data variability.
Submit-DMCP-FGCS-2012-08-31.pdf (1.18 Mo) Télécharger le fichier
hal-00784038 , version 1 (03-02-2013)
Dawei Feng, Cecile Germain-Renaud, Tristan Glatard. Efficient Distributed Monitoring with Active Collaborative Prediction. Future Generation Computer Systems, 2013, 29 (8), pp.2272-2283. ⟨10.1016/j.future.2013.06.001⟩. ⟨hal-00784038⟩
346 Consultations
481 Téléchargements
