Exploration of the core metabolism of symbiotic bacteria - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles BMC Genomics Year : 2012
Ludovic Cottret
Connectez-vous pour contacter l'auteur
Background
A large number of genome-scale metabolic networks is now available for many organisms, mostly bacteria. Previous works on minimal gene sets, when analysing host-dependent bacteria, found small common sets of metabolic genes. When such analyses are restricted to bacteria with similar lifestyles, larger portions of metabolism are expected to be shared and their composition is worth investigating. Here we report a comparative analysis of the small molecule metabolism of symbiotic bacteria, exploring common and variable portions as well as the contribution of different lifestyle groups to the reduction of a common set of metabolic capabilities.
Results
We found no reaction shared by all the bacteria analysed. Disregarding those with the smallest genomes, we still do not find a reaction core, however we did find a core of biochemical capabilities. While obligate intracellular symbionts have no core of reactions within their group, extracellular and cell-associated symbionts do have a small core composed of disconnected fragments. In agreement with previous findings in Escherichia coli, their cores are enriched in biosynthetic processes whereas the variable metabolisms have similar ratios of biosynthetic and degradation reactions. Conversely, the variable metabolism of obligate intracellular symbionts is enriched in anabolism.
Conclusion
Even when removing the symbionts with the most reduced genomes, there is no core of reactions common to the analysed symbiotic bacteria. The main reason is the very high specialisation of obligate intracellular symbionts, however, host-dependence alone is not an explanation for such absence. The composition of the metabolism of cell-associated and extracellular bacteria shows that while they have similar needs in terms of the building blocks of their cells, they have to adapt to very distinct environments. On the other hand, in obligate intracellular bacteria, catabolism has largely disappeared, whereas synthetic routes appear to have been selected for depending on the nature of the symbiosis. As more genomes are added, we expect, based on our simulations, that the core of cell-associated and extracellular bacteria continues to diminish, converging to approximately 60 reactions.
1471-2164-13-438.pdf (1.07 Mo) Télécharger le fichier
1471-2164-13-438-S1.PDF (147.42 Ko) Télécharger le fichier
1471-2164-13-438-S10.PDF (60.12 Ko) Télécharger le fichier
1471-2164-13-438-S11.PDF (118.9 Ko) Télécharger le fichier
1471-2164-13-438-S12.PDF (50.27 Ko) Télécharger le fichier
1471-2164-13-438-S2.PDF (107.81 Ko) Télécharger le fichier
1471-2164-13-438-S3.PDF (31.93 Ko) Télécharger le fichier
1471-2164-13-438-S4.PDF (33.97 Ko) Télécharger le fichier
1471-2164-13-438-S5.PDF (94.73 Ko) Télécharger le fichier
1471-2164-13-438-S6.XLS (740.5 Ko) Télécharger le fichier
1471-2164-13-438-S7.PDF (42.87 Ko) Télécharger le fichier
1471-2164-13-438-S8.PDF (85.71 Ko) Télécharger le fichier
1471-2164-13-438-S9.PDF (54.52 Ko) Télécharger le fichier
1471-2164-13-438.xml (150.17 Ko) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Format : Other
Dates and versions
hal-00784396 , version 1 (04-02-2013)
Identifiers
Cite
Cecilia Coimbra Klein, Ludovic Cottret, Janice Kielbassa, Hubert Charles, Christian Gautier, et al.. Exploration of the core metabolism of symbiotic bacteria. BMC Genomics, 2012, 13 (1), pp.438. ⟨10.1186/1471-2164-13-438⟩. ⟨hal-00784396⟩
272 View
324 Download
Share
