A Domain-Specific Language for Multitask Systems, Applying Discrete Controller Synthesis
We propose a simple programming language, called Nemo, specific to the domain of multitask real-time control systems, such as in robotic, automotive, or avionics systems. It can be used to specify a set of resources with usage constraints, a set of tasks that consume them according to various modes, and applications sequencing the tasks. We automatically obtain an application-specific task handler that correctly manages the constraints (if there exists one), through a compilation-like process including a phase of discrete controller synthesis. This way, this formal technique contributes to the safety of the designed systems, while being encapsulated in a tool that makes it usable by application experts. Our approach is based on the synchronous modelling techniques, languages, and tools.
Domains
Computer Science [cs]
1687-3963-2007-084192.pdf (347.91 Ko)
Télécharger le fichier
1687-3963-2007-084192.xml (15.15 Ko)
Origin : Publisher files allowed on an open archive
Format : Other
