A tight bound for the Delaunay triangulation of points on a polyhedron - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Computational Geometry Année : 2012
We show that the Delaunay triangulation of a set of $n$ points distributed nearly uniformly on a $p$-dimensional polyhedron (not necessarily convex) in $d$-dimensional Euclidean space is $O(n^{\frac{d-k+1}{p}})$, where $k = \lceil \frac{d+1}{p+1} \rceil$. This bound is tight in the worst case, and improves on the prior upper bound for most values of $p$.
2012-dcg-size-delaunay.pdf (215.49 Ko) Télécharger le fichier
Format : Figure, Image
hal-00784900 , version 1 (04-02-2013)
Nina Amenta, Dominique Attali, Olivier Devillers. A tight bound for the Delaunay triangulation of points on a polyhedron. Discrete and Computational Geometry, 2012, 48 (1), pp.19-38. ⟨10.1007/s00454-012-9415-7⟩. ⟨hal-00784900⟩
591 Consultations
258 Téléchargements
