Erasure Codes with a Banded Structure for Hybrid Iterative-ML Decoding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper presents new FEC codes for the erasure channel, LDPC-Band, that have been designed so as to optimize a hybrid iterative-Maximum Likelihood (ML) decoding. Indeed, these codes feature simultaneously a sparse parity check matrix, which allows an efficient use of iterative LDPC decoding, and a generator matrix with a band structure, which allows fast ML decoding on the erasure channel. The combination of these two decoding algorithms leads to erasure codes achieving a very good trade-off between complexity and erasure correction capability.
bandMatrices_submited.pdf (101.07 Ko) Télécharger le fichier
hal-00788318 , version 1 (14-02-2013)
  • HAL Id : hal-00788318 , version 1
Alexandre Soro, Mathieu Cunche, Jérôme Lacan, Vincent Roca. Erasure Codes with a Banded Structure for Hybrid Iterative-ML Decoding. IEEE GLOBAL COMMUNICATIONS CONFERENCE (IEEE GLOBECOM 2009), Nov 2009, Honolulu, United States. pp.746-751. ⟨hal-00788318⟩
151 Consultations
93 Téléchargements
