Automatic dendrite spines detection from X-ray tomography volumes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Xavier Descombes
Grégoire Malandain
Caroline Fonta
We consider the problem of dendritic spine detection from X-ray micro-tomographic volumes that allow huge volume of tissue visualization. To compensate for the noise in data that induces false positives in the spine detection process, we first segment the dendrites. This segmentation is obtained by computing the medial axis and approximating the results by segments obtained with a 3D Hough transform. Dendrites are then reconstructed and a spine mask is obtained using the typical diameter of dendrites and distance between spine and dendrites. A point process is then optimized on this mask, thus providing the spine detection.
Spine.pdf (249.99 Ko) Télécharger le fichier
hal-00793573 , version 1 (22-02-2013)
Xavier Descombes, Grégoire Malandain, Caroline Fonta, Lazlo Negyessy, Rajmund Mosko. Automatic dendrite spines detection from X-ray tomography volumes. ISBI - International Symposium on Biomedical Imaging, Apr 2013, San fancisco, United States. ⟨10.1109/ISBI.2013.6556505⟩. ⟨hal-00793573⟩
280 Consultations
293 Téléchargements
