UML reflections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
UML reflections
The UML shares with reflective architectures the idea that self-de nition of languages and systems is a key principle for building and maintaining complex systems. The UML is now de ned by a four-layer metalevel structure, enabling a flexible and extensible de nition of mod- els by metamodels, and even a self-description of the meta-metamodel (the MOF). This metalevel dimension of UML is currently restricted to structural reflection. But recently a new extension to the UML, called the Action Semantics (AS), has been proposed for standardization to the OMG. This paper explores how this proposed extension brings a behavioural reflection dimension to the UML. Indeed, we show that it is not only possible but quite e ective to use the AS for manipulating UML models (including the AS metamodel). Besides elegant conceptual achievements, such as a metacircular de nition of the AS, reflective mod- eling with the AS leverages on the UML metalevel architecture to provide the bene ts of a reflective approach, in terms of separation of concerns, within a mainstream industrial context. A complete model can now be built as an ideal model representing the core concepts in the application, to which non-functional requirements are integrated as fully traceable transformations over this ideal model. For example, this approach paves the way for powerful UML-de ned semantics-based model transforma- tions such as refactoring, aspect weaving, application of design patterns or round-trip engineering.
Pennaneach01a.pdf (178.86 Ko) Télécharger le fichier
hal-00794325 , version 1 (25-02-2013)
  • HAL Id : hal-00794325 , version 1
François Pennaneac'H, Jean-Marc Jézéquel, Jacques Malenfant, Gerson Sunyé. UML reflections. Proc. of Reflection 2001, Sep 2001, Kyoto, Japan. ⟨hal-00794325⟩
425 Consultations
217 Téléchargements
