A Robust and Entropy-Satisfying Numerical Scheme for Fluid Flows in Discontinuous Nozzles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We propose in this work an original finite volume scheme for the system of gas dynamics in a nozzle. Our numerical method is ased on a piecewise constant discretization of the cross-section and on a approximate Riemann solver in the sense of Harten, Lax and van Leer. The solver is obtained by the use of a relaxation approximation that leads to a positive and entropy satisfying numerical scheme for all variation of section, even discontinuous with arbitrary large jumps. To do so, we introduce in the first step of the relaxation solver a singular dissipation measure superposed on the standing wave which enables us to control the approximate speeds of sound and thus, the time step, even for extreme initial data.
Relaxation_NozzleFlows_FCKSNS.pdf (585.36 Ko) Télécharger le fichier
hal-00795446 , version 1 (28-02-2013)
hal-00795446 , version 2 (28-02-2013)
  • HAL Id : hal-00795446 , version 1
Frédéric Coquel, Khaled Saleh, Nicolas Seguin. A Robust and Entropy-Satisfying Numerical Scheme for Fluid Flows in Discontinuous Nozzles. 2013. ⟨hal-00795446v1⟩
844 Consultations
646 Téléchargements
