De nition of a adaptation methodology of the models of assistance and experimental validation. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
This document is a preliminary version of the working report concerning the work packages 5.3 and 5.4 of the project VolHand 09 VTT 14, that are in charge to the Gipsa-Lab. In this working report, authors introduce the general architecture used to simulate the Electronic Power Steering (EPS) system for a standard and a non-standard driver. In this rst part, the models, the controller and the observer used for the simulation are introduced. Then, the methodology used to adapt the model to a non-standard driver is described in detail. Finally, the experimental validation of this general architecture is proposed. Section 2 refers to the module Gipsa-Comp. Section 3 concerns the module Gipsa-Obs. Section 4 is dedicated to the module Gipsa-Booster. The module Gipsa-Tune is under development.
ValidationExperim_VolHand_ver0.pdf (2.35 Mo) Télécharger le fichier
hal-00797633 , version 1 (06-03-2013)
hal-00797633 , version 2 (12-03-2013)
  • HAL Id : hal-00797633 , version 1
Valentina Ciarla, Carlos Canudas de Wit, Jonathan Dumon, Franck Quaine, Violaine Cahouet. De nition of a adaptation methodology of the models of assistance and experimental validation.. 2013. ⟨hal-00797633v1⟩
490 Consultations
257 Téléchargements
