On ISS and iISS properties of homogeneous systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Several conditions are proposed to check ISS and iISS properties for generic nonlinear systems applying the weighted homogeneity concept (global or local). The advantages of this result is that, under some mild conditions, the system robustness can be established as a function of the degree of homogeneity.
Homogenity_ISS.pdf (273.41 Ko) Télécharger le fichier
hal-00801817 , version 1 (18-03-2013)
  • HAL Id : hal-00801817 , version 1
Emmanuel Bernuau, Andrey Polyakov, Denis Efimov, Wilfrid Perruquetti. On ISS and iISS properties of homogeneous systems. European Control Conference 2013, Jul 2013, Zurich, Switzerland. ⟨hal-00801817⟩
206 Consultations
213 Téléchargements
