Study of a fully implicit scheme for the drift-diffusion system. Asymptotic behavior in the quasi-neutral limit. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2014
In this paper, we are interested in the numerical approximation of the classical time-dependent drift-diffusion system near quasi-neutrality. We consider a fully implicit in time and finite volume in space scheme, where the convection-diffusion fluxes are approximated by Scharfetter-Gummel fluxes. We establish that all the a priori estimates needed to prove the convergence of the scheme does not depend on the Debye length. This proves that the scheme is asymptotic preserving in the quasi-neutral limit.
limite_QN_soumis.pdf (482.93 Ko) Télécharger le fichier
hal-00801912 , version 1 (18-03-2013)
hal-00801912 , version 2 (30-08-2018)
Marianne Bessemoulin-Chatard, Claire Chainais-Hillairet, Marie-Hélène Vignal. Study of a fully implicit scheme for the drift-diffusion system. Asymptotic behavior in the quasi-neutral limit.. SIAM Journal on Numerical Analysis, 2014, 52 (4), pp.1666-1691. ⟨hal-00801912v1⟩
612 Consultations
453 Téléchargements
