Compressed Sensing and Best Approximation from Unions of Subspaces: Beyond Dictionaries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We propose a theoretical study of the conditions guaranteeing that a decoder will obtain an optimal signal recovery from an underdetermined set of linear measurements. This special type of performance guarantee is termed instance optimality and is typically related with certain properties of the dimensionality-reducing matrix M. Our work extends traditional results in sparse recovery, where instance optimality is expressed with respect to the set of sparse vectors, by replac- ing this set with an arbitrary finite union of subspaces. We show that the suggested instance optimality is equivalent to a generalized null space property of M and discuss possible relations with generalized restricted isometry properties.
1569737053.pdf (203.76 Ko) Télécharger le fichier
hal-00812858 , version 1 (12-04-2013)
hal-00812858 , version 2 (11-06-2013)
  • HAL Id : hal-00812858 , version 1
Tomer Peleg, Rémi Gribonval, Mike E. Davies. Compressed Sensing and Best Approximation from Unions of Subspaces: Beyond Dictionaries. 2013. ⟨hal-00812858v1⟩
787 Consultations
274 Téléchargements
