Screen-Space Curvature for Production-Quality Rendering and Compositing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Curvature is commonly employed for enhancing details in textured 3D models, or to modulate shading at the rendering or compositing stage. However, existing methods that compute curvature in object space rely on mesh-based surfaces and work at the vertex level. Consequently, they are not well adapted to production-quality models that rely on either subdivision surfaces with displacement and bump maps, or on implicit and procedural representations. In practice they would require a view-dependent scene discretization at each frame, to adapt geometry to visible details and avoid aliasing artifacts. Our approach is independent of both scene complexity and the choice of surface representations since it computes mean curvature from scratch at each frame in screen-space. It works without any pre-process and provides a controllable screen-space scale parameter, which makes it ideal for production requirements, either during rendering or compositing.
main.pdf (9.85 Mo) Télécharger le fichier
seq_comp-v5.avi (67.97 Mo) Télécharger le fichier
Format : Vidéo
hal-00813560 , version 1 (15-04-2013)
hal-00813560 , version 2 (16-04-2013)
  • HAL Id : hal-00813560 , version 1
Nicolas Mellado, Pascal Barla, Gael Guennebaud, Patrick Reuter, Gregory Duquesne. Screen-Space Curvature for Production-Quality Rendering and Compositing. 2013. ⟨hal-00813560v1⟩
1499 Consultations
1016 Téléchargements
