Tumor Growth Parameters Estimation and Source Localization From a Unique Time Point: Application to Low-grade Gliomas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Vision and Image Understanding Année : 2013
Coupling time series of MR Images with reaction-di usion-based models has provided interesting ways to better understand the proliferative-invasive as- pect of glial cells in tumors. In this paper, we address a di erent formulation of the inverse problem: from a single time point image of a non-swollen brain tumor, estimate the tumor source location and the di usivity ratio between white and grey matter, while exploring the possibility to predict the further extent of the observed tumor at later time points in low-grade gliomas. The synthetic and clinical results show the stability of the located source and its varying distance from the tumor barycenter and how the estimated ratio controls the spikiness of the tumor.
Rekik-CVIU-2013.pdf (1.15 Mo) Télécharger le fichier
hal-00813881 , version 1 (01-07-2013)
Islem Rekik, Stéphanie Allassonnière, Olivier Clatz, Ezequiel Geremia, Erin Stretton, et al.. Tumor Growth Parameters Estimation and Source Localization From a Unique Time Point: Application to Low-grade Gliomas. Computer Vision and Image Understanding, 2013, 117 (3), pp.238--249. ⟨10.1016/j.cviu.2012.11.001⟩. ⟨hal-00813881⟩
415 Consultations
648 Téléchargements
