UBIQUEST, For Rapid Prototyping of Networking Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
An UBIQUEST system provides a high level programming abstraction for rapid prototyping of heterogeneous and distributed applications in a dynamic environment. Such a system is perceived as a distributed database and the applications interact through declarative queries including declarative networking programs (e.g. routing) and/or specific data-oriented distributed algorithms (e.g. distributed join). Case-Based Reasoning is used for optimization of distributed queries when as there is no prior knowledge on data (sources) in networking applications, and certainly no related metadata such as data statistics.
UBIQUEST_For_Rapid_Prototyping_of_Networking_Applications.pdf (889.1 Ko) Télécharger le fichier
hal-00816034 , version 1 (19-04-2013)
Ahmad Ahmad Kassem, Christophe Bobineau, Christine Collet, Etienne Dublé, Stéphane Grumbach, et al.. UBIQUEST, For Rapid Prototyping of Networking Applications. IDEAS 2012 - International Database Engineering & Applications Sysmposium, Aug 2012, Prague, Czech Republic. pp.187-192, ⟨10.1145/2351476.2351498⟩. ⟨hal-00816034⟩
298 Consultations
301 Téléchargements
