Modelling morphological variability of the hippocampus using manifold learning and large deformations
The hippocampus is a structure of the temporal lobe of the brain which plays an important role in memory processes and in many neuropsychiatric disorders, including Alzheimer's disease, epilepsy and schizophrenia. Here, we present a method to infer the anatomical variability of the hippocampus, based on the LDDMM (Large Deformation Diffeomorphic Metric Mapping) framework and a manifold learning approach to capture the geometry of the population in the space of shapes.
Imagerie
HBM_2012_abstract_4.pdf (46.74 Ko)
Télécharger le fichier
poster_HBM12_pekin_4.pdf (2.16 Mo)
Format : Autre
