Stylizing Animation By Example - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2013
Forrester Cole
  • Fonction : Auteur
  • PersonId : 940535
Michael Kass
  • Fonction : Auteur
  • PersonId : 940536
Igor Mordatch
  • Fonction : Auteur
  • PersonId : 940537
James Hegarty
  • Fonction : Auteur
  • PersonId : 940538
Martin Sebastian Senn
  • Fonction : Auteur
  • PersonId : 940539
Kurt Fleischer
  • Fonction : Auteur
  • PersonId : 940540
Davide Pesare
  • Fonction : Auteur
  • PersonId : 940541
Katherine Breeden
  • Fonction : Auteur
  • PersonId : 940542
Skilled artists, using traditional media or modern computer painting tools, can create a variety of expressive styles that are very appeal- ing in still images, but have been unsuitable for animation. The key difficulty is that existing techniques lack adequate temporal coherence to animate these styles effectively. Here we augment the range of practical animation styles by extending the guided texture syn- thesis method of Image Analogies [Hertzmann et al. 2001] to create temporally coherent animation sequences. To make the method art directable, we allow artists to paint portions of keyframes that are used as constraints. The in-betweens calculated by our method maintain stylistic continuity and yet change no more than necessary over time.
keyframe.pdf (45.99 Mo) Télécharger le fichier
Format : Figure, Image
hal-00816143 , version 1 (14-05-2013)
hal-00816143 , version 2 (11-09-2013)
Pierre Bénard, Forrester Cole, Michael Kass, Igor Mordatch, James Hegarty, et al.. Stylizing Animation By Example. ACM Transactions on Graphics, 2013, 32 (4), ⟨10.1145/2461912.2461929⟩. ⟨hal-00816143v1⟩
3727 Consultations
1669 Téléchargements
