Implicit Skinning: Real-Time Skin Deformation with Contact Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2013
Geometric skinning techniques, such as smooth blending or dualquaternions, are very popular in the industry for their high performances, but fail to mimic realistic deformations. Other methods make use of physical simulation or control volume to better capture the skin behavior, yet they cannot deliver real-time feedback. In this paper, we present the first purely geometric method handling skin contact effects and muscular bulges in real-time. The insight is to exploit the advanced composition mechanism of volumetric, implicit representations for correcting the results of geometric skinning techniques. The mesh is first approximated by a set of implicit surfaces. At each animation step, these surfaces are combined in real-time and used to adjust the position of mesh vertices, starting from their smooth skinning position. This deformation step is done without any loss of detail and seamlessly handles contacts between skin parts. As it acts as a post-process, our method fits well into the standard animation pipeline. Moreover, it requires no intensive computation step such as collision detection, and therefore provides real-time performances.
VBGCRWGP_SIGGRAPH_2013.pdf (3.81 Mo) Télécharger le fichier
VBGCRWGP_siggraph_2013_video.mp4 (43.12 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-00819270 , version 1 (30-04-2013)
Rodolphe Vaillant, Loic Barthe, Gael Guennebaud, Marie-Paule Cani, Damien Rohmer, et al.. Implicit Skinning: Real-Time Skin Deformation with Contact Modeling. ACM Transactions on Graphics, 2013, 32 (4), pp.Article No. 125. ⟨10.1145/2461912.2461960⟩. ⟨hal-00819270⟩
1835 Consultations
2249 Téléchargements
