Comparison of index-2 and index-1 DAE solvers for nonsmooth multi- body systems with unilateral or bilateral constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The aim of this work is to study some numerical solvers for the integration of index-1 and index-2 differential algebraic equations that describe the dynamics of constrained mechanical systems, in the framework of event-driven schemes. These solvers will be compared in terms of drift of the constraints, implementation and the way they handle cases when the constraints are not sufficiently differentiable.
MHVAB.pdf (379.83 Ko) Télécharger le fichier
hal-00821315 , version 2 (09-05-2013)
hal-00821315 , version 1 (28-10-2017)
  • HAL Id : hal-00821315 , version 1
Mounia Haddouni, Vincent Acary, Jean-Daniel Beley, Stéphane Garreau. Comparison of index-2 and index-1 DAE solvers for nonsmooth multi- body systems with unilateral or bilateral constraints. 11e Colloque National en Calcul des Structures, May 2013, Giens, France. ⟨hal-00821315v1⟩
376 Consultations
693 Téléchargements
