Correction et amélioration des résultats de la stéréoscopie par corrélation : application au MNE urbain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue Française de Photogrammétrie et de Télédétection Année : 1999
Stereo by correlation can be used to produce urban DEM without a priori knowledge on the shape of buildings, as opposed to feature-based methods. Nevertheless, this method suffers from several weaknesses, e.g. at depth discontinuities located near roof borders. The classical solution is to use a correlation method with adaptive windows [Kanade et Okutomi, 1994], but we propose an alternate solution which consists in post-processing the DEM obtained by correlation. This method is based on a combination of morphomath and anisotropic diffusion techniques, and uses the local contrast of the orthoimage to determine which image areas hooked on the correlation window.
devernay-devade_99.pdf (143.03 Ko) Télécharger le fichier
hal-00821595 , version 1 (13-05-2013)
hal-00821595 , version 2 (14-05-2013)
  • HAL Id : hal-00821595 , version 1
Frédéric Devernay, Julien Devade. Correction et amélioration des résultats de la stéréoscopie par corrélation : application au MNE urbain. Revue Française de Photogrammétrie et de Télédétection, 1999, 153, pp.52-54. ⟨hal-00821595v1⟩
75 Consultations
175 Téléchargements
