Traceability between models and texts through terminology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Data and Knowledge Engineering Année : 2001
Modeling often concerns the translation of informal texts into representations. This translation process requires support for itself and for its traceability. We pretend that inserting a terminology between informal textual documents and their formalization can help to serve both of these goals. Modern terminology extraction tools support the formalization process by using terms as a first sketch of formalized concepts. Moreover, the terms can be employed for linking the concepts and the textual sources. They act as a powerful navigation structure. This is exemplified through the presentation of a fully implemented system.
cerbah2001a.pdf (684.03 Ko) Télécharger le fichier
hal-00822907 , version 1 (15-05-2013)
Farid Cerbah, Jérôme Euzenat. Traceability between models and texts through terminology. Data and Knowledge Engineering, 2001, 38 (1), pp.31-43. ⟨10.1016/S0169-023X(01)00015-5⟩. ⟨hal-00822907⟩
77 Consultations
227 Téléchargements
