Modular Composition Modulo Triangular Sets and Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Complexity Année : 2013
We generalize Kedlaya and Umans' modular composition algorithm to the multivariate case. As a main application, we give fast algorithms for many operations involving triangular sets (over a finite field), such as modular multiplication, inversion, or change of order. For the first time, we are able to exhibit running times for these operations that are almost linear, without any overhead exponential in the number of variables. As a further application, we show that, from the complexity viewpoint, Charlap, Coley, and Robbins' approach to elliptic curve point counting can be competitive with the better known approach due to Elkies.
poteaux-schost.pdf (454.57 Ko) Télécharger le fichier
hal-00825843 , version 1 (24-05-2013)
Adrien Poteaux, Éric Schost. Modular Composition Modulo Triangular Sets and Applications. Computational Complexity, 2013, pp.1-54. ⟨10.1007/s00037-013-0063-y⟩. ⟨hal-00825843⟩
126 Consultations
145 Téléchargements
