Local/Global Scene Flow Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The scene flow describes the 3D motion of every point in a scene between two time steps. We present a novel method to estimate a dense scene flow using intensity and depth data. It is well known that local methods are more robust under noise while global techniques yield dense motion estimation. We combine local and global constraints to solve for the scene flow in a variational framework. An adaptive TV (Total Variation) regularization is used to preserve motion discontinuities. Besides, we constrain the motion using a set of 3D correspondences to deal with large displacements. In the experimentation our approach outperforms previous scene flow from intensity and depth methods in terms of accuracy.
quiroga-lgsceneflow-icip2013.pdf (172.21 Ko) Télécharger le fichier
hal-00829515 , version 1 (03-06-2013)
  • HAL Id : hal-00829515 , version 1
Julian Quiroga, Frédéric Devernay, James L. Crowley. Local/Global Scene Flow Estimation. ICIP - IEEE International Conference on Image Processing, Sep 2013, Melbourne, Australia. ⟨hal-00829515⟩
583 Consultations
619 Téléchargements
