Equivalence and comparison of heterogeneous cellular networks
We consider a general heterogeneous network in which, besides a general propagation effects (shadowing and-or fading), individual base stations may use different emitted powers and be subject to different parameters of the Hata-like propagation loss model (path-loss exponent and constant), e.g. due to different antenna heights. We assume also that the stations may have various and different engineering parameters, e.g. of link layer performance (SINR threshold, etc). Studying a propagation processes of signals received by the typical user from all antennas marked by the corresponding antenna parameters we show that, seemingly different, heterogeneous networks based on Poisson point processes of BS, may be equivalent from the point of view a typical user characteristics. Furthermore, they all can be replaced with a model where all the previously variable propagation parameters (including path-loss exponent) are set to constants while the only trade-off being the introduction of an isotropic base station density. This allows one to perform analytic comparisons of different network models via their isotropic representations. In the case of a constant path-loss exponent, the isotropic representation becomes just a homogeneous modification of the constant intensity of the original network, thus generalizing a previous result showing that the propagation processes only depend on some moment of the emitted power and propagation effects. We give examples and applications to motivate these results and highlight an interesting observation regarding random path-loss power exponents.
