Image Classification with the Fisher Vector: Theory and Practice - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2013
Florent Perronnin
  • Fonction : Auteur
  • PersonId : 928545
Thomas Mensink
  • Fonction : Auteur
  • PersonId : 940630
A standard approach to describe an image for classification and retrieval purposes is to extract a set of local patch descriptors, encode them into a high dimensional vector and pool them into an image-level signature. The most common patch encoding strategy consists in quantizing the local descriptors into a finite set of prototypical elements. This leads to the popular Bag-of-Visual words (BoV) representation. In this work, we propose to use the Fisher Kernel framework as an alternative patch encoding strategy: we describe patches by their deviation from an "universal" generative Gaussian mixture model. This representation, which we call Fisher Vector (FV) has many advantages: it is efficient to compute, it leads to excellent results even with efficient linear classifiers, and it can be compressed with a minimal loss of accuracy using product quantization. We report experimental results on five standard datasets - PASCAL VOC 2007, Caltech 256, SUN 397, ILSVRC 2010 and ImageNet10K - with up to 9M images and 10K classes, showing that the FV framework is a state-of-the-art patch encoding technique.
journal.pdf (380.97 Ko) Télécharger le fichier
Format : Figure, Image
hal-00830491 , version 1 (05-06-2013)
hal-00830491 , version 2 (12-06-2013)
  • HAL Id : hal-00830491 , version 1
Jorge Sanchez, Florent Perronnin, Thomas Mensink, Jakob Verbeek. Image Classification with the Fisher Vector: Theory and Practice. International Journal of Computer Vision, 2013. ⟨hal-00830491v1⟩
6002 Consultations
24265 Téléchargements
