Path Functors in Cat - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We build an endofunctor in the category of small categories along with the necessary structure on it to turn it into a path object suitable for homotopy theory and modelling identity types in Martin-L\ ̈of type theory. We construct the free Grothendieck bifibration over a base category generated by an arbitrary functor to that category.
PathFunctorsInCat.pdf (374.9 Ko) Télécharger le fichier
hal-00831430 , version 1 (07-06-2013)
hal-00831430 , version 2 (30-08-2013)
hal-00831430 , version 3 (19-09-2013)
  • HAL Id : hal-00831430 , version 3
François Lamarche. Path Functors in Cat. 2013. ⟨hal-00831430v3⟩
285 Consultations
1846 Téléchargements
