Towards Many Gestures to One Command: A User Study for Tabletops - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Multi-touch gestures are often thought by application designers for a one-to-one mapping between gestures and commands, which does not take into account the high variability of user gestures for actions in the physical world; it can also be a limitation that leads to very simplistic interaction choices. Our motivation is to make a step toward many-to-one mappings between user gestures and commands, by understanding user gestures variability for multi-touch systems; for doing so, we set up a user study in which we target symbolic gestures on tabletops. From a first phase study we provide qualitative analysis of user gesture variability; we derive this analysis into a taxonomy of user gestures, that is discussed and compared to other existing taxonomies. We introduce the notion of atomic movement; such elementary atomic movements may be combined throughout time (either sequentially or in parallel), to structure user gesture. A second phase study is then performed with specific class of gesture-drawn symbols; from this phase, and according to the provided taxonomy, we evaluate user gesture variability with a fine grain quantitative analysis. Our findings indicate that users equally use one or two hands, also that more than half of gestures are achieved using parallel or sequential combination of atomic movements. We also show how user gestures distribute over different movement categories, and correlate to the number of fingers and hands engaged in interaction. Finally, we discuss implications of this work to interaction design, practical consequences on gesture recognition, and potential applications.
paperFINAL.pdf (509.94 Ko) Télécharger le fichier
hal-00831877 , version 1 (07-06-2013)
hal-00831877 , version 2 (04-04-2017)
  • HAL Id : hal-00831877 , version 1
Yosra Rekik, Laurent Grisoni, Nicolas Roussel. Towards Many Gestures to One Command: A User Study for Tabletops. INTERACT - 14th IFIP TC13 Conference on Human-Computer Interaction, Nelson Mandela Metropolitan University, CSIR Meraka Institute and the University of Cape Town, Sep 2013, Cape Town, South Africa. ⟨hal-00831877v1⟩
Collections
CRISTAL-MINT
852 Consultations
464 Téléchargements
