MULTI-CRITERIA SEARCH ALGORITHM: AN EFFICIENT APPROXIMATE K-NN ALGORITHM FOR IMAGE RETRIEVAL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new method for approximate k-NN search in large scale image databases, based on top-k multi-criteria search techniques. The method defines a simple index structure based on sorted lists, which provides a good compromise between fast retrieval, stor- age requirements and update cost. The search algorithm delivers approximate results with guarantees about false negatives, with fast emergence of good approximations, monotonically improved and leading if necessary to an exact result. Experiments with the on-disk implementation show that our method produces very good approximate results several times faster than the Baseline method.
badr13icip.pdf (1.51 Mo) Télécharger le fichier
hal-00832196 , version 1 (10-06-2013)
hal-00832196 , version 2 (12-06-2013)
  • HAL Id : hal-00832196 , version 1
Mehdi Badr, Dan Vodislav, David Picard, Shaoyi Yin, Philippe-Henri Gosselin. MULTI-CRITERIA SEARCH ALGORITHM: AN EFFICIENT APPROXIMATE K-NN ALGORITHM FOR IMAGE RETRIEVAL. IEEE International Conference on Image Processing, Sep 2013, Melbourne, Australia. ⟨hal-00832196v1⟩
Collections
ETIS-MIDI
605 Consultations
790 Téléchargements
