A single sediment-Microbial Fuel Cell powering a wireless telecommunication system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Power Sources Année : 2013
We report the ability of a single sediment-Microbial Fuel Cell (MFC) to power wireless sensor network (WSN) nodes. Such a system is able to collect information from sensors and to transmit it to sinks. In particular, the PowWow platform presented here is combining an open and modular hardware design with an open-source software with a very light memory footprint and relying on event-driven programming. It includes energy harvesting capabilities and is able to adapt its radio data transmission behavior to the available energy supplied by the sediment-MFC. The MFC developed in this study successfully powered the WSN and results showed very stable performances over a long time frame with a high rate of signals sent from a source to a receptor connected to a computer. This sediment-MFC is moreover simple to produce and handle, with no membrane or artificial catalysts.
preprint_j_power_sources_2013.pdf (524.44 Ko) Télécharger le fichier
hal-00832354 , version 1 (11-06-2013)
hal-00832354 , version 2 (24-06-2013)
Yohann R J Thomas, Matthieu Picot, Arnaud Carer, Olivier Berder, Olivier Sentieys, et al.. A single sediment-Microbial Fuel Cell powering a wireless telecommunication system. Journal of Power Sources, 2013, 241, pp.703-708. ⟨10.1016/j.jpowsour.2013.05.016⟩. ⟨hal-00832354v1⟩
733 Consultations
1478 Téléchargements
