Plane wave stability of the split-step Fourier method for the nonlinear Schrödinger equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Forum of Mathematics, Sigma Année : 2014
Plane wave solutions to the cubic nonlinear Schrödinger equation on a torus have recently been shown to behave orbitally stable under generic perturbations of the initial data that are small in a high-order Sobolev norm, over long times that extend to arbitrary negative powers of the smallness parameter. The present paper studies the question as to whether numerical discretizations by the split-step Fourier method inherit such a generic long-time stability property. This can indeed be shown under a condition of linear stability and a non-resonance condition that can both be verified if the time step-size is restricted by a CFL condition. The proof uses a Hamiltonian reduction and transformation and modulated Fourier expansions in time and provides detailed insight into the structure of the numerical solution.
hal-00833007 , version 1 (11-06-2013)
Erwan Faou, Ludwig Gauckler, Christian Lubich. Plane wave stability of the split-step Fourier method for the nonlinear Schrödinger equation. Forum of Mathematics, Sigma, 2014, 2 (e5), 45 p. ⟨10.1017/fms.2014.4⟩. ⟨hal-00833007⟩
389 Consultations
0 Téléchargements
