Alternative Financial Solutions seeking via a Genetic Like Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
In this paper we build a method to optimize Multi-Year Prospective Budgets. First we present a systemic model of Local Community Finances. Then, from two acceptable Multi-Year Prospective Budgets the method implements a Genetic Algorithm to generate a collection of admissible Multi-Year Prospective Budgets among which Decision-Makers can choose. The method is tested on simplified cases and on in operational situation and gives satisfactory results.
TwPoiPbFreGouTou.pdf (1.04 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00833327 , version 1 (12-06-2013)
hal-00833327 , version 2 (20-12-2013)
Emmanuel Frenod, Jean-Philippe Gouigoux, Landry Touré. Alternative Financial Solutions seeking via a Genetic Like Algorithm. 2013. ⟨hal-00833327v1⟩
1208 Consultations
407 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
