Muscle as a Metamaterial Operating Near a Critical Point - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review Letters Année : 2013
The passive mechanical response of skeletal muscles at fast time scales is dominated by long range interactions inducing cooperative behavior without breaking the detailed balance. This leads to such unusual ''material properties'' as negative equilibrium stiffness and different behavior in force and displacement controlled loading conditions. Our fitting of experimental data suggests that ''muscle material'' is finely tuned to perform close to a critical point which explains large fluctuations observed in muscles close to the stall force.
Caruel_2013_Phys._Rev._Lett.pdf (351.78 Ko) Télécharger le fichier
hal-00834683 , version 1 (17-06-2013)
hal-00834683 , version 2 (25-06-2013)
Matthieu Caruel, Jean-Marc Allain, Lev Truskinovsky. Muscle as a Metamaterial Operating Near a Critical Point. Physical Review Letters, 2013, 110, pp.248103. ⟨10.1103/PhysRevLett.110.248103⟩. ⟨hal-00834683v1⟩
561 Consultations
243 Téléchargements
