Registration of a Validated Mechanical Atlas of Middle Ear for Surgical Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper is centered on the development of a new train- ing and rehearsal simulation system for middle ear surgery. First, we have developed and validated a mechanical atlas based on finite element method of the human middle ear. The atlas is based on a microMRI. Its mechanical behavior computed in real-time has been successfully val- idated. In addition, we propose a method for the registration of the mechanical atlas on patient imagery. The simulation can be used for a rehearsal surgery with the geometrical anatomy of a given patient and with mechanical data that are validated. Moreover, this process does not necessitate a complete re-built of the model.
paper_313.pdf (950.83 Ko) Télécharger le fichier
hal-00838431 , version 1 (25-06-2013)
  • HAL Id : hal-00838431 , version 1
Guillaume Kazmitcheff, Christian Duriez, Mathieu Miroir, Yann Nguyen, Olivier Sterkers, et al.. Registration of a Validated Mechanical Atlas of Middle Ear for Surgical Simulation. MICCAI 2013, 2013, Nagoya, Japan. ⟨hal-00838431⟩
244 Consultations
342 Téléchargements
