Analysis of Social Navigation for a Robot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
This article describes the different approaches cur- rently followed in the field of social navigation for robots. A novel approach focusing on human activ- ity called the Maisonasse attentional model is stud- ied in more depth as well as its implementation in the robot operating system (ROS).
AvdBerg_TER_report.pdf (228.64 Ko) Télécharger le fichier
hal-00839360 , version 1 (27-06-2013)
  • HAL Id : hal-00839360 , version 1
Andre van den Berg. Analysis of Social Navigation for a Robot. [Research Report] 2013. ⟨hal-00839360⟩
123 Consultations
467 Téléchargements
