Experimentation with large scale ICN multimedia services on the Internet made easy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Communications Society Multimedia Communications Technical Committee E-Letter Année : 2013
In this paper we present a framework for evaluating ICN solutions in general, and multimedia solutions in particular. This framework simplifies the challenges of conducting large scale experiments on the wild Internet. We leverage on the existing PlanetLab testbed to provide worldwide distributed access to the Internet at minimum cost, and propose the NEPI tool to simplify the design and deployment of experiments. As a means of illustrating the capabilities of the framework, we consider an example experiment in which we evaluate the performance of broadcasting video to over 100 consumers using CCNx against a classical client-server solution.
MMTC_Eletter_ICN.pdf (181.1 Ko) Télécharger le fichier
hal-00840235 , version 1 (02-07-2013)
  • HAL Id : hal-00840235 , version 1
Alina Quereilhac, Daniel Camara, Thierry Turletti, Walid Dabbous. Experimentation with large scale ICN multimedia services on the Internet made easy. IEEE Communications Society Multimedia Communications Technical Committee E-Letter, 2013, 8 (4), pp.10-12. ⟨hal-00840235⟩
278 Consultations
319 Téléchargements
